fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
magnus98
Jan 05, 2016Aspirant
What exactly is the trick to getting these cameras to sync with the router? I have the latest firmware (V1.0.6.28_1.1.83) for the router. The arlo site says that my router is offline and the router shows that that it does not have a connection. However, I am connected to the internet with the router using a wired connection. Also, the wireless connection says that it is off even though it is on. What in the world is wrong with this firmware? Is anyone else having these issues?
I got one of the cameras added but it does not seem to be connected and the router itself does not show on the router.
