fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Hot54321
Jan 06, 2016Apprentice
Killhippie
If i get the option to hide the ssid, that must to be worked in the firmware. Otherwise isn't build in.
rpoffen
Jan 06, 2016Virtuoso
I have seen some client devices that don't work well with a hidden SSID, so it may not entirely be the router at fault.
There are a number of options in the router that many people probably should not play around with, you sometimes really need to know specifically what you are getting in to.
