fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Killhippie
Jan 07, 2016Prodigy
Yes but it doesnt make it a good idea just because its there to fiddle with it, 20/40 Coexistance is there but it should really be left to 20 unless you live in a field in the middle of nowhere, otherwise you can mess up not only your neighbours but your own network. Leave the SSID visable and use a good strong WPA2 AES password, thats all the security you really need, same as mac filtering, so easy to spoof its not worth turning on and in some cases causes issues with some clients.
mondenath
Jan 07, 2016Prodigy
I dont agree mac filtering cant be spoofed. Hacking is always there but if mac filtered it hard to get in not like impossible. Unless no one takes so hard to get in simple wifi nw unless a huge worth behind it.
Nighthawk cant just be simply hacked with some simple client . You need to genius in nw to do that finding the loophole and bruteforce with advanced technique.
- chopin70Jan 07, 2016Virtuoso
LoL, MAC filtering doesn't need a hacker, just a teenager, but a bit smart to just do a google for the needed tools ;-)
