fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
LeKeiser
Jan 09, 2016Luminary
Hello all,
One thing that I didn't do when I upgraded the firmware was to do a reset right after the upgrade. I thought "I just upgraded it, so it must be good"
Then I noticed that my downloads weren't as good as before. So today, I wanted to try a previous firmware, so I did a reset again, went back to factory configuration WITH the latest firmware, and just before I tried the other firmware, I decided to check my download bandwith. And there is was again, close to 720Mb again. So I just re-applied my configuration and everything is working again great.
So really: reset, firmware, reset.
I know it's been told and told before, but... :)
So far, the latest firmware, .6.28 is very good.
