fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
LeKeiser
Jan 09, 2016Luminary
The 5Ghz band seems to be good, I've tried both my One+ and my LG tablet and they both have a clear and fast signal. I'll try my laptop later, but there is no doubt that it will connect fast and easy :)
I'll update this post when I'm on my laptop.
ankydu
Jan 09, 2016Guide
I have the latest firmware now, and other than not being able to login to the router in Router mode via my PC connected via LAN port, I dont have any other issues with the latest firmware.
EDIT: Now am not able to login to the router in 1.0.4 firmware as well after I upgraded to the latest firmware, but not much of an issue as I use the router in Wireless AP mode and in that everything works. So at the moment am sticking with 1.0.6.28.
- LeKeiserJan 09, 2016Luminary
Weird... Of course you've tried with different browsers, emptied the cache, and so on? No restriction on the configuration?
- ankyduJan 09, 2016Guide
Yeh everything and more than what I could think of, including 3-4 resets with each firmware.
I'm sure I've missed your posts and so I might write something that you've already done and done again, but... :
1) can you ping the router from your PC?
2) have you tried rebooting your computer safe mode?
3) while your computer is connected to the router with the LAN cable, what attached devices do you see if you use let's say a WiFi device (tablet, computer,...?) I've had one tablet that I had configured in the access devices, Mac Address and all, but I had to authorise it with another tablet when it tried to connect...
