fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
ankydu
Jan 11, 2016Guide
I have kaspersky Internet security, which I cannot uninstall, but I disabled it's protection and exited all its processes from the task manager, just to be sure. Secondly when booting in safe mode with networking kaspersky is not allowed to load by windows, there as well can't access the router.
- chopin70Jan 11, 2016Virtuoso
In fact, your network configuration looks fine under windows with ipconfig /all
If you really did all what you said, and mainly hard reset + connect only one cable between PC and Router, maybe something else corrupted in router or windows. Again, on first hard reset with this 1.06, I had to connect to the WAN from my PC. There was no way to connect using the LAN. After that, using the LAN worked. Why? I have no clue. Just try it as a last chance
If a fresh install of windows is able to connect to the router, then it is an issue with your current windows install, else it is something fishy in router. Provided hardware interface (adapter and cable) is fine!
For windows, many things can affect it. Did you try to look if 192.168.1.(0-255) range is redirected in hosts file ? (%SystemRoot%\System32\drivers\etc\hosts)
If you excluded a windows issue by a fresh install, let's say, it is sad that no Netgear dev ever replies for support here. Their NAS forum is extremely well supported by Team devs. Here, users are left alone it seems
- tarundJan 17, 2016Apprentice
I had a similar issue as well on my desktop with Kaspersky. I had to uninstall it completely in order to be able to connect to my router. Pain in the butt, I tell ya. I'm on 1.0.4.30 as well but going to try the latest and do the factory reset. Let's see where it takes me.
- KillhippieJan 18, 2016ProdigyAn interesting thing is when accessing it using Google Chrome, Chrome reports the connection having been "reset". This means the computer is connecting to the router but something is forcing a disconnect. But, sometimes it works and other times it doesn't. Plus, connecting to other home networked computers can be next to impossible.
But, I located the culprit to be KIS and it can easily be corrected. Do the following on all your machines and your networks will function fine.
1) Right click on the red K on the lower right of your screen
2) Left click settings
3) Left click Protection
4) Left click Firewall
5)Left click Networks
6) Find the adapters for your wired & wireless ports and change them to "Local Network"
7) Close the networks page
8) Left click Configure Packet Rules
9) Find "Any network activity (Local network)"
10) Right click on it and select edit
11) Check the "inactive" box
12) Left click close
Exit all pages and reboot the machine. You're good to go! (from kaspersky support pages)- ankyduJan 18, 2016Guide
Does not work for me, when I do all the steps your have given, am still not able to access the router, instead of connection reset I get ERR NETWORK ACCESS DENIED in browsers.
