fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
oertje
Jan 12, 2016Aspirant
I have updated it but now no 2.4ghz accespoint I have no wifi only at 5ghz
what can I do?
- scornell2288Jan 12, 2016GuideWindows
2016-01-11 07:58 AM
Here is the fix to all or our problems. I tested this last night.
Go here:
http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/
Sign up for account.
Download latest version.
The recommended procedure:
1. Reset your router to factory defaults via (Push reset button for 8 seconds on the R7000) Log into 192168.1.1 follow default steps.
2. Flash the R7000_xxx.xx_x.chk file via the web interface.
3. Do another factory reset via the new web interface.
4. Configure everything else.I did this last noght it is a very stable and really cool Firmware. My wireless range and speeds increased as well. This firmware was built for the R7000
- ankyduJan 14, 2016Guide
I am done with this buggy, worst than alpha firmware. Firstly if not being able to open my router page wasnt enough now all my android phones and tablet refuse to detect my HP AIO printer on this firmware, only my windows devices with netgear software are able to detect it. With great disappointment from netgear, I am reverting back to 1.0.4.30 where atlest the things I need work if not everything.
