fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
ankydu
Jan 11, 2016Guide
I have kaspersky Internet security, which I cannot uninstall, but I disabled it's protection and exited all its processes from the task manager, just to be sure. Secondly when booting in safe mode with networking kaspersky is not allowed to load by windows, there as well can't access the router.
tarund
Jan 17, 2016Apprentice
I had a similar issue as well on my desktop with Kaspersky. I had to uninstall it completely in order to be able to connect to my router. Pain in the butt, I tell ya. I'm on 1.0.4.30 as well but going to try the latest and do the factory reset. Let's see where it takes me.
