fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
superartificial
Jan 23, 2016Aspirant
R8000 at home and a R7000 at my "man cave" :-)
01R
Jan 23, 2016Luminary
i got a wierd problem since i upgraded to this firmware sometimes the router reports that im gettin smurf attacks sometimes from my own modem is it the fw or real smurf attacks any one else have this problem ?
