fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Vash
Jan 23, 2016Aspirant
I tried to get an Arlo single camera setup with the Netgear R7000. I've already done a factory router reset and have the latest firmware. No dice. I've got a worthless camera and a wasted Saturday. Initially, I was able to get the router synced with my Arlo account, but the camera wouldn't sync. Then, the camera wouldn't sync with the router. Then, once the camera sync worked no video and the camera status always said "Busy". After multiple iterations of removing and adding the router etc from my Arlo account, now the Arlo app can't even discover my router. My router currently shows one offline camera on the Arlo portion of the router config. The Arlo app and My Arlo site don't reflect any devices. Really frustrated.
- KillhippieJan 24, 2016ProdigyAnything to do with your computers firewall and AV?
