fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Vash
Jan 24, 2016Aspirant
It shouldn't. My AV isn't on currently due to an incompatibility with the current beta version of OS X and I don't have a standalone software-based firewall active.
Plus, I had previously been able to add/remove the router from my Arlo device list multiple times while troubleshooting the camera sync issue. Now, nothing. No devices can be detected or synced. I also tried using the Arlo iOS app which should preclude the possibility of anything on my MacBook Pro having any effect.
- JamesGLJan 24, 2016NETGEAR Employee Retired
Hi Vash,
Just to verify if you have followed the steps on the KB article below:
- VashJan 24, 2016Aspirant
Yes, I did. This AM I just did a factory reset, reinstalled firmware, and another factory reset. After manually reconfiguring my router, the router finally showed up for the Arlo iOS app to be added to my account. After a couple tries, I was also able to add the Arlo camera. Although, now the camera won't display video. First, the camera shows as "Busy" in the Arlo app. After rebooting my router and modem, the camera didn't show "Busy" anymore in the Arlo app. The camera does, however, now show "Offline" in both the Arlo app and the R7000 router configuration Arlo menu.
- KillhippieJan 24, 2016Prodigy
You must be running a very early version of 10.11.4 then. Tbh you should not run beta software on your main machine anyway, i'm runningg 10.11.3 with no issues at all. Also what AV, OS X does not play kindly with most AV"s I would say Malwarebytes is all you raelly need for a mac at this time, and common sense. didnt you partion your drive so you had at least a working version of the latest supported release?
