fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
ptgeorge
Feb 02, 2016Aspirant
My Issues with 1.0.6.28_1.1.83
*Smart Connect does not work with secure applications such as Good email client
*Smart Connect roaming from one band to the other results in disconnect requiring manual WiFi release/reconnect.
Killhippie
Feb 03, 2016Prodigy
smart connect is really not worth using tbh. Just use two different SSID's and pick the one that gives you what you need eithe on 5Ghz or 2.4 Ghz
