fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
bytat
Feb 05, 2016Tutor
revert back to v 4.0.28.. it's the latest stable release.. if you're like me, in europe, you can set the region on Japan for DFS channels in the 5ghz band.
I've been trying out every new firmware and the added, sometimes working, features aren't worth the trouble and stability issues that the later firmwares are plauged with.
omoeller
Feb 05, 2016Guide
Just received another announcement from Netgear that they have released R7000 Firmware Version 1.0.5.48 - what GREAT news
Not sure what they are doing there but it feels support and development are a bit lost ....
I can only tell that after moving to XVORTEX all my problems are gone, super WLAN performance on both ranges, cool tools to manage mobile.
I think this will be my last NETGEAR router after some time .... sad :-(
