fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Ubimo
Feb 18, 2016Aspirant
I recommend using dd-wrt firmware. I ran into many problems with the latest firmware.
Download and flash this: http://desipro.de/ddwrt/K3-AC-Arm/dd-wrt.K3_R7000.chk
Pros:
Awesome, fast and stable firmware with lots of settings you usually don't see with stock firmware.
Cons:
none
My R7000 is running stable since two weeks, no reboots, no WAN connection losses. Just smile :-)
Brakiss
Feb 19, 2016Aspirant
Have you tested Samba shares? I cannot get mine to work on newest DDWRT
