fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
arekm
Feb 19, 2016Aspirant
Also downgraded to V1.0.4.30_1.1.67 due to network instability with latest fw :-/ Switching hardware to Turris Omnia Router as soon as it is delivered to me.
netwrks
Feb 20, 2016Master
arekm wrote:Also downgraded to V1.0.4.30_1.1.67 due to network instability with latest fw :-/ Switching hardware to Turris Omnia Router as soon as it is delivered to me.
I have read breifly about the Turris Omnia router. Let us know how the new router works out when you get it, or post something on Small Net builder..
- mondenathFeb 27, 2016Prodigy
Here you go. Another Beta firmware.
- shamarinFeb 27, 2016Virtuoso
Cool. And where to find details on what is changed or modified?
Its still under Beta Q&A testing from Engg team. But i just flashed and it was working fine with significant load time improvement
GUI loads faster as like 5.48
Port forwarding still works
Arlo issues should have been fixed.
Better wifi stability
All functions are working intact as 5.48 fw.
Overall Much improved version than 6.28
