fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Retired_Member
Mar 02, 2016Yup i did a reset twice...the 2.4 ghz does work...but it does not work right,I dont know whats going on with it? It has a long delay or something? When i use it on my wireless things like my samsung 5 etc...lap tops etc...the internet keeps spinning and spinning...like the hour glass on a lap top...just has this long delay? And takes like 50 seconds for a screen to pop up at all...such as if i try going on facebooks app on my phone it just spins away or sometimes just doesent connect at all...as soon as i switched to the 5 ghz earlier its been fine...no delays at all! But yes i did a hard reset twice...I have no idea whats going on??? It was fine before the update
