fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Retired_Member
Mar 02, 2016You mean download the firmware onto a usb drive? Then download it into the usb jack on the nighthawk? And whats the difference? If it does not work right by doing it online? Then why is there an option to do it that way? And i never did a reset before i did it...no one told me too? Or i wasn't told to when i did it...I did 2 resets after i did it because its not working right
Killhippie
Mar 02, 2016Prodigy
I just go to the netgear site and download the firmware to my computer. Reset the router login, update the firmware (by Ethernet never over wifi) reset it again once its updated and rebooted itself, then add all my settings. Never had any issues. You have not turned off WMM or 20/40 coexistence have you? Both should be left at their default values, especially 20/40 Coexistence unless you live in the middle of a forest and have no wifi networks near you.
