fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Gmember
Mar 05, 2016Aspirant
Don't get it.......can't find this firmware on the netgear website.... latest firmware is Version 1.0.4.30....
I do have the 1.0.6.28 firmware but got all kinds of troubles, can't remote acces the router with the genie app, harddrives do function well on my network but not visible in the readycloud etc. etc. and yes everything is registered and all ;)
So i wanted to try and re-upgrade this firmware from local storage instead OTA and see if things get better.....
But as i said before.....can't find it on the netgear site
TheEther
Mar 05, 2016Guru
Gmember wrote:Don't get it.......can't find this firmware on the netgear website.... latest firmware is Version 1.0.4.30....
Netgear pulled the release due to bugs. They are testing a new release. Keep checking every few days. It should come out, hopefully soon.
