fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Retired_Member
Mar 06, 2016Im fine waiting! Actually i really dont care if they come out with a new one or not! The 104 version works fine! You know the old saying if it's not broke don't fix it! The only thing that pisses me off is the lady on the phone talking about an $89 package and other packages just to get some help with this! Sure lady I'll pay almost the same amount that I paid for my router just to figure out what I already knew...
- JamesGLMar 06, 2016NETGEAR Employee Retired
Hi All,
The latest firmware was pulled out from support site due to some issues reported. A beta firmware has been released in some community posts for you to try if you are interested. You may download it here. Official firmware will be released as soon as QA team are done testing it.
