fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Retired_Member
Mar 07, 2016Because i was commenting mostly about the fact that they wanna charge people $89 and up for their mistakes thats why im here! And no i wont use beta...Im not using experimental software that never works right...
JayBee7
Mar 07, 2016Aspirant
I ended up switching to Merlin - v378.56_2 and have not looked back. Even the Netgear 1.0.4.30 firmware gave me the same issues with my WAN dropping. I did a full reset and re-configured so there was no dodgy backup and I still had issues.
I work in IT and things like this happen, in saying that, how they have the gall to charge $89 to fix their mistake? Not a good look IMO...
