fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
jordy5
Apr 19, 2016Tutor
Alright,
I've got Arlo camera's so I'm stuck with the beta firmware. Running: V1.0.6.40_1.1.90 now in AP mode.
So far not happy with the R7000
- Every now and then when i login to the router it states: "Updating Settings" and it will reset the modem. Not really great.. as you can imagine. I can, after the reset, login to the router.
- Some Arlo camera's are getting disconnect every now and then (1 every 2 to 4 days). Reset r7000 through Arlo app fixes the problem. Never had this issue with the Arlo basestation in place. As you don't receive any push messages when arlo lost it's connection this is not great.
Is there any new firmware implementing a more stable connection.. otherwise i will need to hook up the basestation again... :(
Venosaur
Apr 19, 2016Tutor
install beta version it will help
