fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
netwrks
Apr 22, 2016Master
Most of the user's problems on this forum is the reluctance to reset their router's to factory default after upgrading firmware (this version or others).
Venosaur
Apr 22, 2016Tutor
do You think reset after upgrade or before ? :)
- KillhippieApr 23, 2016Prodigy
I do both but if you only do one, always after...
- VenosaurApr 23, 2016Tutor
I hope that the newst version will be soon :)
