fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
Cat6aPlease
Apr 23, 2016Star
LeKeiser wrote:
upgrade, and since then, my router has been running great and my wall feels better.
That is another data point, however people on this message board should not apply their own anecdotal experience to everyone, much like my anecdotal experience of continued failure after factory reset does not apply to you.
LeKeiser
Apr 23, 2016Luminary
Cat6aPlease wrote:
LeKeiser wrote:
upgrade, and since then, my router has been running great and my wall feels better.That is another data point, however people on this message board should not apply their own anecdotal experience to everyone, much like my anecdotal experience of continued failure after factory reset does not apply to you.
This is a forum, people share their experience so that they can solve their problems with their router...
What do you expect to read on this forum but bad experiences? When people are satisfied, they don't come here.
Or when they do, it's to help others. That's what I'm trying to do. I've had a good experience with this upgrade, so I share.
What do you do yourself?
