fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
shamarin
Apr 26, 2016Virtuoso
Will try it.
chilicheech
May 24, 2016Aspirant
1.0.5.64 released today: https://kb.netgear.com/app/answers/detail/a_id/30695 .. http://www.downloads.netgear.com/files/GDC/R7000/R7000-V1.0.5.64_1.1.88.zip
- shamarinMay 24, 2016Virtuoso
Good news. Allready updated my router.
- VenosaurMay 25, 2016Tutor
I have updated also.
I have question because i have two R7000 and on one of them i have icon of program Netgear Downloader Beta. Can You explain me this ?
I updated two and now shows on both the same that is means is ok :
sorry and Regards
- anygregMay 25, 2016Apprentice
Will I loose all my port forward settings with this update?
Really nervous of updating this router as the past one killed the whole network.
- IrvSpMay 25, 2016Master
