sb2016
Oct 08, 2016Tutor
R7000 new Firmware disables Access Control
I am using Nighthawk R7000 in "Access Point Mode". With the prior Firmware Version (don't remember the version): I was able to use the "Access Control" link on the Advanced->Attached Devices pag...
- Nov 18, 2016
Access Control feature is disabled in AP mode per design and not considered as a bug.
Pluto8
Dec 23, 2016Apprentice
I am a little bit puzzled by this discussion:
I have an R7000 as main router and another R7000 as access point. Both are now running firmware 1.0.7.6_1.1.99. I thought only the main router should handle the access control and give out IP addresses, not the access point. If the access point also should handle this, then you would have to add all the access control information in both routers (which is very inconvenient).
So as far as I can see, the graying out of the access control information in the access point is correct.
But maybe I am wrong?
OmerFaruk
Dec 23, 2016Tutor
My situation is a bit different, so maybe that will explain it: On my Modem/Router combo device (The one I got from my internetprovider), I disabled the Wireless functionality, and I use the R7000 as AP. So all my wireless devices only connect through the R7000.
