sb2016
Oct 08, 2016Tutor
R7000 new Firmware disables Access Control
I am using Nighthawk R7000 in "Access Point Mode". With the prior Firmware Version (don't remember the version): I was able to use the "Access Control" link on the Advanced->Attached Devices pag...
- Nov 18, 2016
Access Control feature is disabled in AP mode per design and not considered as a bug.
sb2016
Dec 17, 2016Tutor
I got an email today asking me to upgrade the firmware to fix security issue #582384. http://kb.netgear.com/000036470/R7000-Firmware-Version-1-0-7-6
I am not sure if this version will have the bug fix that we are asking for; enable Access Control in "Access Point" mode.
FDM2
Dec 24, 2016Aspirant
No it doesn't fix the issue It was that verision that caused me to lose access control.
- StephenBDec 24, 2016Guru - Experienced User
You could downgrade firmware, since the AP web ui is protected by your main router. The security vulnerability doesn't have much risk in that case.
The other option is to find a way to use the R7000 as the router, not just an AP.
Both are workarounds of course (not trying to say otherwise).
