sb2016
Oct 08, 2016Tutor
R7000 new Firmware disables Access Control
I am using Nighthawk R7000 in "Access Point Mode". With the prior Firmware Version (don't remember the version): I was able to use the "Access Control" link on the Advanced->Attached Devices pag...
- Nov 18, 2016
Access Control feature is disabled in AP mode per design and not considered as a bug.
slash1981
Jan 04, 2017Tutor
While I agree that Access Control feature is not quite needed on the router in AP mode (it's enough to control access via Access Control feature on the main router) what I don't understand is how Access Control feature should function in Netgear's understanding...
Just for a sake of testing I changed access for one of my wireless devices to "Blocked". Voila - no Internet access. HOWEVER, I was still able to easily access all my network shares on my LAN. In my understanding security of the private network (LAN) is way more important than security of public WAN (Internet).
So, Netgear, what's the purpose of this Access Control feature if the only access that it controls is access to the Internet?
ElaineM
Jan 16, 2017NETGEAR Employee Retired
Per engineering, there are no plans to add Access Control in AP mode.
slash1981 Have you submitted that case with support?
- slash1981Jan 16, 2017Tutor
ElaineM wrote:slash1981 Have you submitted that case with support?
No I have not. While your products are usually of a good quality, your Support team is terrible. Taking into account my mostly negative experience while dealing with Netgear Support in the past - I didn't really bother opening a case.
Wierd though that you need a case for an issue like that. I mean, it's pretty basic - access control feature should be either blocking or allowing access. Your ACL blocks this access partially. It is my understanding that this should've been caught during QA.
- ElaineMJan 16, 2017NETGEAR Employee Retired
While it's true that QA should have caught it but then it could be an isolated issue.
However, in your case I strongly suggest submitting a case to support team for verification.
You can submit a case online.
ElaineM wrote:While it's true that QA should have caught it but then it could be an isolated issue.
I do not have "Submit a new online support ticket" option available. Only "Contact Support" as shown HERE. Might be because I have never registered my two R7000's...
