Nobbygas
Nov 01, 2022Aspirant
R7000 new install. Getting 'no router found'.
I can see the router being broadcast on my phone, but it has no internet connection. It should connect to my existing home router. I cannot access the router using ANY of the methods mentioned. Route...
michaelkenward
Nov 01, 2022Guru - Experienced User
You have two routers in your network?
What are they?
See the questions from plemans
Nobbygas
Nov 02, 2022Aspirant
Hello. The second router is a normal Fritz Box. It's the household router. I intend to use the Nighthawk as a VPN router, if I can ever connect to it that is ! I live in Germany.
- NobbygasNov 02, 2022Aspirant
If I connect the Nighthawk directly to my PC via an Ethernet cable and Ping 192.168.1.1 I get no response.
- michaelkenwardNov 02, 2022Guru - Experienced User
You are just flailing around. Plugging random things into random sockets isn't going to work.
You need to understand what you are doing and follow instructions.
Some of these things are best left to a network professional.
Thanks. I previously had a TP-link AC1750 Router I used for VPN access. This worked fine until ExpressVPN pulled the plug on the L2TP support and it stopped working. It wasn't capable of supporting OpenVPN so I switched to this Nighthawk Router.
Please go back to the beginning and re-read the first message from plemans.
Without a model number who knows what a "normal Fritz Box" is? (Wikipedia lists several dozen.) But you probably have two routers on your network. That is almost certainly the cause of your problems.
plemans explains where you should look for solutions.
Here is some more:
What is Double NAT? | Answer | NETGEAR SupportThat covers the VPN issue.
and then
How to fix issues with Double NAT | Answer | NETGEAR Support
You need to deal with the NAT problem before you can begin to set up the R7000 for VPN.
It should not take too much effort, but you do have to follow the advice that you have been offered.
