annistyt
Dec 21, 2017Aspirant
R7000 Nighawk Internet speed limited
So I connected my ethernet cable to my pc and I checked on speedtest to verify and test the internet speed. We have fiber and our download/upload speed is 500/50 mbps. When I tested on speedtest I on...
- Dec 22, 2017
Things that people have tried to fix the "router is throttling my modem" issue with various devices:
- Ensure that the cable from the router to the modem is up to the job
- Check that you have the latest firmware (and "factory reset" the device)
- Check that you have the right internet settings for your ISP (especially MTU)
- Turn off QoS
- Turn off the Traffic Meter
Netgear also advises that you should turn off QoS if you are on Gigabit Internet. You don't need it.
michaelkenward
Dec 22, 2017Guru - Experienced User
- Turn off QoS
- annistytDec 22, 2017Aspirant
I did a factory reset and I got 500/50 on speedtest, thank you
- michaelkenwardDec 22, 2017Guru - Experienced User
And yet there are still people who see no point in a factory reset. It doesn't always help, but it seems silly to not even try it.
Thanks for the feedback.
- MichaelFLJan 03, 2018Apprentice
I actually created a post today. I found that the issue was / is Access Control. It was NOT a problem for years. But now it is. If I disable it, my internet speeds are back to 1gig support (900+Mbps) both directions. When I enable it it drops and stays at 200Mbps both directions.
Easy to repro. It repro's on the current, previous and current / beta versions of the firmware.
Yeap I did factory resets, reboots, wiped everything. Initially it worked. I thought great. Then I re-enabled Access Control and my speeds dropped.. Disable it, it fixes it and so on...
