barnettr
May 09, 2022Aspirant
R7000 Nighthawk - No Internet Connection
Hello...this one really has me perplexed. When I log into my router, the main page always says 'Internet - Not Connected'. However...all WIFI devices that are managed by my router ARE are connected...
- May 09, 2022
Wow 3 years with out a reset. Thats probably pretty good run. Yes I would reset and setup from scratch and see if this helps, if not, Try updating FW.
May 09, 2022Guru - Experienced User
What broswer are you using? Happens in a different browser?
Be sure to clear out all browser caches before entering the routers web page.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Also there is newer FW available:
barnettr
Hello FLURRYe38...
Thanks for the quick reply. Thinking about this more...I believe it started when we converted from Charter (cable coax connection) to our new ISP which brings the Internet to the house via fiber. There is only a small black box (I guess this is the modem) that has its own power supply, a jack that connects the fiber to the modem and an ethernet outlet that I connect to the router.
I have tried multiple browsers all with the same result. I have cleared all cache, etc. I have also powered off the router and dropped power to the fiber box (modem). I waited 3-4 minutes and brought power up in the suggested sequence. Same result. I don't think I can get a firmware download until we resolve this issue with the Router connecting to the Internet, right?
I'm convinced there is some setting in the Netgear software that is not right. Maybe I should call my ISP to see if they have any ideas on this?
Again...I want to point out that all WiFi enabled devices that run through this Router (including a NetGear extender) have no problems accessing the Internet. It is only the R7000 router.
Thanks for any other ideas you may have!
RB
- FURRYe38May 09, 2022Guru - Experienced User
What is the CAT# lan cable that connects the router to the ISP modem/ONT? CAT6 is recommended.
Has the router ever been factory reset since last FW update?
You might review the more recent FW update. I've had this loaded on my R7000. Saw nothing like this.
If you can get internet services, and get the FW manually downloaded, you can manually install new FW:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- barnettrMay 09, 2022Aspirant
OK...
Yes...I am using CAT-6 to run from the ISP installed Fiber Box to the Router.
And no...I have not done a 'factory reset' to the router since I installed it 3 years ago. I have always downloaded the latest firmware to keep the unit current. So you are thinking perhaps I need to do a factory reset? I assume when you do a factory reset it reverts to the 'out of the box' admin ID and Password? I'll also need to review any other settings I've made because I'll lose those too...
Thx.
