barnettr
May 09, 2022Aspirant
R7000 Nighthawk - No Internet Connection
Hello...this one really has me perplexed. When I log into my router, the main page always says 'Internet - Not Connected'. However...all WIFI devices that are managed by my router ARE are connected...
- May 09, 2022
Wow 3 years with out a reset. Thats probably pretty good run. Yes I would reset and setup from scratch and see if this helps, if not, Try updating FW.
barnettr
Hello FLURRYe38...
Thanks for the quick reply. Thinking about this more...I believe it started when we converted from Charter (cable coax connection) to our new ISP which brings the Internet to the house via fiber. There is only a small black box (I guess this is the modem) that has its own power supply, a jack that connects the fiber to the modem and an ethernet outlet that I connect to the router.
I have tried multiple browsers all with the same result. I have cleared all cache, etc. I have also powered off the router and dropped power to the fiber box (modem). I waited 3-4 minutes and brought power up in the suggested sequence. Same result. I don't think I can get a firmware download until we resolve this issue with the Router connecting to the Internet, right?
I'm convinced there is some setting in the Netgear software that is not right. Maybe I should call my ISP to see if they have any ideas on this?
Again...I want to point out that all WiFi enabled devices that run through this Router (including a NetGear extender) have no problems accessing the Internet. It is only the R7000 router.
Thanks for any other ideas you may have!
RB
May 09, 2022Guru - Experienced User
What is the CAT# lan cable that connects the router to the ISP modem/ONT? CAT6 is recommended.
Has the router ever been factory reset since last FW update?
You might review the more recent FW update. I've had this loaded on my R7000. Saw nothing like this.
If you can get internet services, and get the FW manually downloaded, you can manually install new FW:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- barnettrMay 09, 2022Aspirant
OK...
Yes...I am using CAT-6 to run from the ISP installed Fiber Box to the Router.
And no...I have not done a 'factory reset' to the router since I installed it 3 years ago. I have always downloaded the latest firmware to keep the unit current. So you are thinking perhaps I need to do a factory reset? I assume when you do a factory reset it reverts to the 'out of the box' admin ID and Password? I'll also need to review any other settings I've made because I'll lose those too...
Thx.
- FURRYe38May 09, 2022Guru - Experienced User
- michaelkenwardMay 10, 2022Guru - Experienced User
The reset has nothing to do with new firmware. There is no reason why you should reset a router just because it has new firmware, Your problem is completely different.
You have moved the router from one Internet service to something completely different.
During the setup process, the router detects the Internet service and adapts its settings accordingly. So you have a router set up for cable Internet that is running on "fibre". It is no surprise that the thing is not performing as expected.
- barnettrMay 10, 2022Aspirant
Hey Michael,
Thanks for your input too. As noted, we did change from a Cable provider to a Fiber provider. After the Fiber installer disconnected the Cable and connected the Fiber, all the devices using this Router came up fine and connected to the Internet. I really didn't think anything more about it until a week or so ago I logged on to the Router via Routerlogin.net and noticed it said 'No Internet'. I'm beginning to think it has to be some sort of software glitch to be giving this false message, don't you? Obviously the Router IS connected to the Internet or none of the other devices would be working. Maybe at the time we converted from cable to fiber I should have done a Factory Reset before we brought the new ISP on-line.
Thoughts?
RB
