barnettr
May 09, 2022Aspirant
R7000 Nighthawk - No Internet Connection
Hello...this one really has me perplexed. When I log into my router, the main page always says 'Internet - Not Connected'. However...all WIFI devices that are managed by my router ARE are connected...
- May 09, 2022
Wow 3 years with out a reset. Thats probably pretty good run. Yes I would reset and setup from scratch and see if this helps, if not, Try updating FW.
barnettr
OK...
Yes...I am using CAT-6 to run from the ISP installed Fiber Box to the Router.
And no...I have not done a 'factory reset' to the router since I installed it 3 years ago. I have always downloaded the latest firmware to keep the unit current. So you are thinking perhaps I need to do a factory reset? I assume when you do a factory reset it reverts to the 'out of the box' admin ID and Password? I'll also need to review any other settings I've made because I'll lose those too...
Thx.
May 09, 2022Guru - Experienced User
