msg2000
Sep 10, 2024Aspirant
R7000 Nighthawk- Cant access router settings in browser or app
I recently noticed on my iphone in my wifi that I have weak security WEP. It recommends upgrading to WPA2 or WPA3. I have been to the routerlogin.net or .com and never se the login after doing all of...
sktn77a
Sep 10, 2024Virtuoso
routelogin.net should get you to the router login page. Put in the username and password you assigned and it takes you to the router dashboard. From here you can change all those settings.
