msg2000
Sep 10, 2024Aspirant
R7000 Nighthawk- Cant access router settings in browser or app
I recently noticed on my iphone in my wifi that I have weak security WEP. It recommends upgrading to WPA2 or WPA3. I have been to the routerlogin.net or .com and never se the login after doing all of...
msg2000
Sep 11, 2024Aspirant
Thanks Michael, I think what I was reacting to on my iphone was in the wifi setting I was not connected to 5G and was instead at 2.4. and I didnt realize that. I guess thats why the message blow on my iphone said the security was weak. So I switched to 5G and the message below on the wifi setting on my phone didnt say "Weak Security" under it anymore.
michaelkenward wrote:Are you trying to get into the router's controls with the web browser and the graphical user interface (GUI)?
Yes originally I was trying the GUI approach but the login screen doesn't display, even after clearing cache in browsers. All I ever see is the login page with download and shop options. At the base of the page it has troubleshooting steps for each browser to clear cache and I tried all of those and still see the same page when I enter the url they listed for login. Ill attach what I see.
So the other option I have seen on this page
https://kb.netgear.com/27199/I-can-t-access-my-router-what-do-I-do
mentions using the app as the recommended way to edit settings on the router
Within the app I cant get to a router settings edit mode only the armor security promo.
Is there a way to edit router settings in the app?
michaelkenward
Sep 11, 2024Guru - Experienced User
Not the ones I pointed to. The app is there to manage just basic stuff. It has some control over WiFi security, based on the firmware and the hardware.
Check the WiFi settings tile.
But there is more that you can do with the GUI.
That you can't access that may be worth pursuing. What happens when you use a browser?
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
A wired connection is best, but a browser on a mobile can also get in there.
The usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Having two routers on a network can cause headaches. For example, you can end up with local address problems.
Also check this with you iOS device:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
Just another user with time on their hands.
