Livvy51's avatar
Livvy51
R7000 Nighthawk AC1900 home network via TP Link Powerlines
Have recently purchased a separate Nighthawk AC1900 wifi router to use in conjunction with my Cable modem. I am having real issues re-setting up my existing home network. My cable modem (virgin media...
  • antinode's avatar
    Aug 23, 2017
    > My cable modem (virgin media super hub) is situated in upstairs and
    > connects to my Nighthawk downstairs via a paired TP link powerline.
       If this works, then I'd guess that you connected a Powerline device
    to the WAN ("Internet") port on the R7000.
       If you add more Powerline devices to that Powerline network, then
    they'll be talking to the WAN port on the R7000, where they'll generally
    be ignored by the R7000.
       Client devices must be connected to LAN ports on the R7000, not the
    WAN port (which normally should be connected to only the modem).
       It should be fine to use Powerline devices to expand the LAN, but
    that network must be isolated from the modem-router connection.  I
    gather that this can be done:
          http://www.tp-link.com/us/faq-433.html
          Can several Powerline networks exist simultaneously in same power
          circuit?
          Yes.
          The powerline networks can be separated by different network
          names.  [...]
