drbretto
Oct 29, 2021Tutor
R7000 Nighthawk AC1900 keeps resetting to factory settings randomly
Randomly occasionally turn on my PC to find that R7000 is blocking access to most webstires. The only fix appears to be to go to 192.168.1.1 and re-do the initial setup. It happened twice today,...
Oct 29, 2021Guru - Experienced User
Routers do not have a battery.
Be sure to save off a back up configuration to file for safe keeping.
