Buffalo_Rick's avatar
Buffalo_Rick
Initiate
Aug 15, 2017
R7000 Nighthawk antennas
How do I keep them from flopping over? Connection to router is tight on all three but they don't hold a position I put them in such as the recommended 45 degrees for the outer two?
  • I solved it. I had the antennas at a 45 degree angle rather than straight out when I was twisting them on, so they were not on all the way. When they were straight out I could twist them in further so that when I stood them up they held the position I put them in.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Buffalo_Rick,
    Can you provide a picture of the Antennas flopping over.
    • Buffalo_Rick's avatar
      Buffalo_Rick
      Initiate
