Bdad's avatar
Bdad
Follower
May 22, 2016
R7000 Nighthawk Firmware Version V1.0.6.28_1.1.83
Running the FW shown in the title. What version should I be running for performance and stability?
  • ElaineM's avatar
    ElaineM
    May 31, 2016
    Bdad We have released a new official firmware 1.0.5.64. See this link for the release notes.
    This should also fix 2.4GHz issues. Feel free to update, reset and reconfigure. Provide us details should you encounter any problems.
    • Retired_Member's avatar
      Retired_Member
      1.0.5.62 is a beta which for me is working good so far. Their has been some issues reported when changing output levels, wifi settings are lost and need to be re-entered. I don't change output so I don't see it as an issue, NO ARLO so that's fine with me too.
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
