Redk
Apr 28, 2022Aspirant
R7000 Nighthawk in AP mode blocking UDP port
I have an R7000 Nighthawk installed in AP mode. There is a UDP port blocked that I need opened but I see no way to configure that. When I put my old AP (other brand) back in place of the nighthawk, th...
michaelkenward
Apr 28, 2022Guru - Experienced User
Did you find this?
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Redk
Yes, the port forward setup is disabled when in AP mode. So, how do I get the unit to not block my UDP traffic to port 1434?
- FURRYe38Apr 28, 2022Guru - Experienced User
Port Forwarding is not supported in AP mode. Any blocking of ports will need to be configured at the main host router that the R7000 in AP mode is connected too.
- RedkApr 28, 2022Aspirant
That's the problem. The Nighthawk is blocking my access to the port forwarding and I don't have access to anything to correct this. So, how do I get the Nighthawk to not block my traffic?
- michaelkenwardApr 28, 2022Guru - Experienced User
In AP mode, the R7000 is attached to a router. As FURRYe38 says, the sort of thing you want to achieve is down to the router.
So, forget about tweaking the R7000, investigate how to do things in the unnamed main router in your network.
If you have problems, go back to your initial request:
Explain what it is that you really want to do – like getting a particular gadget to work – and maybe you will get better answers.
