mzinkan
Jul 11, 2016Aspirant
R7000 Nighthawk Locks/Blocks CD/DVD Drive
Hello, R7000 Nighthawk updated to latest firmware within the past month. I don't know where to find the version via the Genie software, but there are no newer firmware updates available to me. ...
- Dec 07, 2016
Hello Again Folks,
Yesterday afternoon, Netgear sent me an email wanting me to to test a new version of Genie. Upon opening my email today and seeing the notice, I downloaded and installed the updated version and put it to tthe test.
I am happy to report that I did not find any issues with this updated version of the Genie software!!!
I would guess that it will be made available for download soon.
Sincerely.
Mike Zinkan
reedaf4
Dec 13, 2016Aspirant
afraid tech support ran out on my R8500 Nighthawk router already. this issue happened well after my 90 day support period. that's why I was in this forum looking for help. basic problem after a fresh hard drive/OS reinstall and software reinstall on my computer with last software installed being Netgear Genie. when I installed prigram, none of my CD drives could read the discs. if I uninstalled Gebie, the CD drives all read discs properly. this issue repeated itself again as noted above using latest Genie version 2.4.34. no resolution. kind of stuck with no fix.
mzinkan
Dec 14, 2016Aspirant
reedaf4, until the revised version of Genie is made available to the public, may I suggest that you:
1. right-click on the Genie icon in your systray
2. choose Settings
3. uncheck Enable Autostart
4. click Exit
You can then reboot your PC, if desired.
Genie will no longer automatically start, and your CD/DVD drive should work as you would expect it to.
If you need to use Genie for any reason (it's not necessary that it run unti needed), simply open the program from the icon on your desktop. When finished using Genie, simply right-click the icon in your systray and click Exit. Since it is set to not autostart, you should have no problems again.
Best Regards,
Mike
