hougene
Jul 15, 2016Aspirant
R7000 nighthawk need to be reset everyday
I use this router for apple TV, Sony phone, iPhone, they are able to connect 5G signal, but I need to reset the router for Macbook pro to search the 5G signal everytime When I need to connect. Is ...
- Jul 18, 2016
I changed the channel of my 5 GHz from 36 to 153,
changed 2.4GHz to 12,
then my macbook pro is able to connect and search the 5GHz SSID,
maybe I lived in a building apartment,
too many channel are interferred together,
so my iphone can connect but macbook doesn't.
You should check your area with the same channel,
it may affect your connection.
Thanks for you guys support.
I sort it out eventually
VE6CGX
Jul 16, 2016Master
Did it work alright before f/w update? If yes go back to previous f/w. Instead of resetting, try rebooting. Resetting need reconfiguration or restoring saved configuration file. My router never needs resets or reboot. It just runs and runs for months and on once put into service. When things are running good I don't need to update f/w. Do you read release note first when you update f/w? Was there anything specially applicable to your router operation?
hougene
Jul 18, 2016Aspirant
