Simms24
Dec 19, 2024Follower
R7000 nighthawk not working
i recently was moving stuff around my router and accidently unplugged it i went to plug it back in and it is no longer working i only have one ethernet cable plugged in at the moment and the internet...
Dec 20, 2024Guru - Experienced User
Solid amber power light tends to indicate a hardware or boot up failure.
You can try recovering it with tftp or nmrpflash.
Are you on Windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walkthrough using a TFTP client. Use the built-in one for Windows 10, though. The video is more of an example of how it's done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Here's a video of nmrpflash: https://www.youtube.com/watch?v=qxQu3wtpFYo
