caddyshack1's avatar
caddyshack1
r7000 nighthawk router wifi not broadcasting
Hey all, I just installed a new modem (Surfboard SB6183) and activated it with my ISP.  The router has an active wired ethernet connection as that is what I'm using to post this message.  For some ...
  • antinode's avatar
    Dec 19, 2018
    > [...] the status is showing as a red "X" next to both the 2.4 and 5.0
    > GHz signals.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "Top and Front
    Panels" and "Table 1. LED and button descriptions".
       What do the LED indicators indicate?  Did you press the "WiFi On/Off
    button with LED"?
       If you get desperate, then look in the User Manual for "Factory
    Settings".
