DA-LEGEND121
Apr 03, 2021Tutor
R7000 Nighthawk Router Won't Factory Reset
Hi all, I was configuring my Nighthawk R7000 router to be used as an extended but somethign went wrong and it turned off. Now it keeps going through a bootloop and shows the amber power light for 1 m...
- Apr 06, 2021
I fixed it. There was a specific command on another website and it instantly unbricked my router. Thanks for you help.
Apr 04, 2021Guru - Experienced User
Many things can go wrong with tftp. where did it fail in the process?
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- DA-LEGEND121Apr 04, 2021Tutor
I am currently trying to fix it using nmrpflash but when I use the nmrpflash -L to determine the correct network interface, it says that no suitable network interfaces were found. Another thing that I noticed with the router is that the power led won't blink amber and is stuck on solid amber for some reason. How do I fix this?
- DA-LEGEND121Apr 06, 2021Tutor
- plemansApr 06, 2021Guru - Experienced User
what command was it? Might help someone else if they're having that issue
