DA-LEGEND121
Apr 03, 2021Tutor
R7000 Nighthawk Router Won't Factory Reset
Hi all, I was configuring my Nighthawk R7000 router to be used as an extended but somethign went wrong and it turned off. Now it keeps going through a bootloop and shows the amber power light for 1 m...
- Apr 06, 2021
I fixed it. There was a specific command on another website and it instantly unbricked my router. Thanks for you help.
DA-LEGEND121
Apr 04, 2021Tutor
I am currently trying to fix it using nmrpflash but when I use the nmrpflash -L to determine the correct network interface, it says that no suitable network interfaces were found. Another thing that I noticed with the router is that the power led won't blink amber and is stuck on solid amber for some reason. How do I fix this?
DA-LEGEND121
Apr 06, 2021Tutor
- plemansApr 06, 2021Guru - Experienced User
what command was it? Might help someone else if they're having that issue
- DA-LEGEND121Apr 06, 2021Tutor
The command that unbricked my router was "nmrpflash -i netx -f Firmware.File version".
Replace netx with the proper net port that the router is connected to and replace firmware.file version with the name of the firmware that you downloaded.
