acius14
Dec 01, 2016Aspirant
r7000 nighthawk wifi router CANT ACESS my DVR with cameras from outside my network using cell or PC
Cant open certain port on r700 Niighthawk
- Dec 05, 2016
Hi I down graded to Ver.1.0.5.70 firmware, reset to factory end my problem went away-now i can use my DVR outside my network.
JamesGL
Dec 02, 2016NETGEAR Employee Retired
Hi acius14,
1. What are the ports numbers that cannot be opened?
2. What tool did you use to check the ports?
3. Have you verified with ISP if the ports are not blocked from their end?
4. Have you open the ports on port forwarding of the router?
JamesGL
Community Team
acius14
Dec 02, 2016Aspirant
Hi
I can not open potrs;95, 5921.Sofrware to check ports:portforward, canyouseeme,portchecker.
The only port 80 end 5920 are open.Yesterday i spend 45 min. on the phone with my ISP-THEY DO NOT BLOCK PORT 95 END 5921 from their end. Those ports are open on port forwarding ofthe router.
Softwareim using PC TO WATCH dvr with cameras: CMS Pro Ver 3.30.52 -using this software i see my cameras ONLY inside my house usinh Wi-fI or LAN. My CELL SOFTWARE: mViewer Pro Ver.1.12.24.
Using mu cell i can not connect to my DVR at all even inside my Wi-Fi or outside my house-mobile data on my cell are turn ON.
Thx Acius14
