GamerX102
Jun 05, 2016Aspirant
R7000 Nighthawk Wired Connection Is Much Faster than Wireless
I'm using an R7000 Nighthawk currently and after testing internet speeds using speedtest.net, I found that a desktop that is directly connected with ethernet is more than 100 Mbps faster than a...
- Jun 06, 2016
Thanks to everyone who tried to help, but there was an IT friend of my dad who came and said it was a certain chip (or something of the sort) in my computer that was wrong, so we got a Linksys Max-Stream AC600 Wi-Fi Micro USB Adapter. I can now get 90 Mbps on download. Thanks again for everyone's help.
GamerX102
Jun 06, 2016Aspirant
- IrvSpJun 06, 2016Master
That is probably due to the security your PC was capable of using. Probably couldn't handle AES and had to use TKIP. See here, http://www.makeuseof.com/tag/use-aes-tkip-faster-wi-fi-network/, and from it:
TKIP is a deprecated encryption method, and apart from security concerns, it’s known to slow down systems that still run it.
So you have to select "WPA-PSK [TKIP] + WPA2-PSK [AES]" in security to use it. I'm sure the new USB device uses AES.
Not uncommon on older (5 years or more) PC's/Laptop's, especially 'cheaper' ones.
