Cassidy62
May 21, 2019Aspirant
R7000 Nighthawk Won't factory reset. I enabled the password recovery feature and can't restore.
After pressing the reset on router and have enabled the password recovery feature. I can't get pass the two security questions. Any help Please.
- May 22, 2019
All good. After going through sevral resets. Switching to another computer seamed to do the trick. Thx
May 22, 2019Guru - Experienced User
You reset it and then setup the password recovery and now can't get in? Is this correct?
If so, you'll need to reset it again. Avoid special characters for password resets and make sure there aren't any spaces.
if your title is correct and you can't reset it at all, where is it failing?
You list 2 different routers. R7000 in title and R7800 in signature. Which is it? Firmware on it?
