xjjeep96
Jan 26, 2018Tutor
R7000 Nighthawk Won't factory reset
Have hit reset several times...cycles through but comes right back up connected to the internet, and password/login hasn't been reset to default admin/password....any suggestions?
- Jun 13, 2018@michaelkenwa
I fixed the issue; please see the thread above (now, rejected. So, writting again below) Thanks for your quick response. The TFTP2 came from and KB by netgear: https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
Here is the the fix and details on what happened:
- After clicking on “A router firmware upgrade is available” and flushing with new firmware, my router didn’t work anymore. As I stated earlier, only ‘blinking white’ light were showing.
- I tried doing factory reset, and didn’t work.
- Then followed this instruction: https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTPto flush the firmware. It didn’t work.
- I called the customer service and spent about an hour, trying different things they suggested, and nothing worked. It was a mixed experience. While, the technical support representative were nice and tried what she could do to help me and my router was out of warranty, she didn’t offer anything that I couldn’t find in goggle. At then end, when she failed she said sorry and that was it. I know the router was out of warranty and they were not going to do anything about it. However, I think they should take more responsibility for failed update for a $200 router.
- So, after asking technical support representation told me that the $200 device is now a piece of brick and I already spent 2+ hours to fix it, I decided to give up and start driving to Costco/BestBuy to get an new router (obviously not a NetGear). Before, I give up, I sent this message as a last resort, and tried one final thing.
- I followed: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-softbricked/td-p/414034 with some Tweak,
Note: the guide has a mistake and use windows tftp not as the KB suggested by NeatGear.
& the correct command will be:
tftp -i 192.168.1.1 put firmware.chk (-i was missing form the instruction)
This did the trick, and I was able to use the router again.
I hope this is help someone else save 3 hours of different trial and error.
Thanks
970222
Jun 09, 2018Guide
I tried all these things (tftp2, 30,30,30 reset, etc) and I can't get to reset the router. The power light is "bliking white". Any other suggestion? or is this a $200 brick now? (out of warrenty)
michaelkenward
Jun 09, 2018Guru - Experienced User
A bli[n]king white power light can be a sign that you are in recovery mode.
tftp (where did the 2 come from?) is notoriously hard to get right.
How are you going about that?
As a newcomer to this discussion, and the forum (welcome to the funny farm), you might like to tell us a bit more about what you have done and what happened.
- IrvSpJun 09, 2018Master
Not clear on this one at all? Sounds like one initial problem, resetting router did NOT put the UID and P/W back to default values... and now has done a myriad of things and it really having a blinking white LED problem?
I know at 'one time' doing the reset DID erase the UID and P/W and put it back to default. This was some time ago on much older firmware. I also know that when I tried less than a year ago this did NOT happen. Entered UID and P/W remained.
Suspect this would have been a change in the firmware at some point?
- 970222Jun 13, 2018Guide@michaelkenwa
Thanks
- Blanca_OJun 19, 2018NETGEAR Employee Retired
Hi 970222,
Glad to hear that you got it working.
Blanca
Community Team
