Seabee20's avatar
Aug 18, 2017
R7000 Nighthawk
I'm really stuck & hope someone can help! I just switched Internet Service Provider ! I have Spectrum now, a cable company. The signal to the Modem they provided is great, but my router isn't distribu...
  • Seabee20's avatar
    Seabee20
    Aug 18, 2017
    No sir! I wasn't confused! Yes, I was connected by wire & I tried wireless also! I was suspecting my cable & switched it out! My WiFi antenna may have had something to do with the issue! I put in my wireless utility CD & re-downloaded the driver & so far it is working!
    Thank you so much for your suggestions! I really appreciate it!
